跳转到主内容
Samsung NP-130-JA01US Keyboard Replacement
你所需要的
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Keyboard Replacement: 步骤 2 中的图像 1,2 Samsung NP-130-JA01US Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Keyboard Replacement: 步骤 5 中的图像 1,3 Samsung NP-130-JA01US Keyboard Replacement: 步骤 5 中的图像 2,3 Samsung NP-130-JA01US Keyboard Replacement: 步骤 5 中的图像 3,3
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
  6. Samsung NP-130-JA01US Keyboard Replacement: 步骤 6 中的图像 1,3 Samsung NP-130-JA01US Keyboard Replacement: 步骤 6 中的图像 2,3 Samsung NP-130-JA01US Keyboard Replacement: 步骤 6 中的图像 3,3
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 的会员
USFT-LACY-F16S9G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 243
