跳转到主内容
Samsung NP-130-JA01US Hard Drive Replacement
你所需要的
  1. Samsung NP-130-JA01US Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Hard Drive Replacement: 步骤 2 中的图像 1,2 Samsung NP-130-JA01US Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Samsung NP-130-JA01US Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Using a Philips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Hard Drive Replacement: 步骤 5 中的图像 1,3 Samsung NP-130-JA01US Hard Drive Replacement: 步骤 5 中的图像 2,3 Samsung NP-130-JA01US Hard Drive Replacement: 步骤 5 中的图像 3,3
    • With the plastic opening tool, carefully separate the back cover from the computer frame.
    • Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
    • Do not attempt to pry it open, putting too much force into one location might damage the computer.
    • As you go around the sides of the computer, free the inside latches with the plastic opening tool.
    • Once you have an opening, carefully use your hands to separate the back cover.
  6. Samsung NP-130-JA01US Hard Drive Replacement: 步骤 6 中的图像 1,2 Samsung NP-130-JA01US Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Locate Hard Drive (red square)
    • Using a Phillips 1 screw driver, remove the screw marked in the red circle.
    • The screw is a Phillips 1 (PH 1) with a length of 40 millimeters (mm)
    • Unscrew carefully to prevent losing or breaking pieces.
  7. Samsung NP-130-JA01US Hard Drive Replacement: 步骤 7 中的图像 1,2 Samsung NP-130-JA01US Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Gently remove the hard drive.
结论
另外一个人完成了本指南。
Jorge Quintana
于10/05/16注册
260 声望
撰写一个指南
团队
USF Tampa, Team 9-6, Lacy Fall 2016 USF Tampa, Team 9-6, Lacy Fall 2016 的会员
USFT-LACY-F16S9G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 723
