跳转到主内容
Samsung NP N310 HAA2US Cooling Fan Replacement
你所需要的
  1. Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: 步骤 2 中的图像 1,2 Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: 步骤 2 中的图像 2,2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Cooling Fan Replacement: 步骤 3 中的图像 1,3 Samsung NP N310 HAA2US Cooling Fan Replacement: 步骤 3 中的图像 2,3 Samsung NP N310 HAA2US Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
  4. Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: 步骤 4 中的图像 1,2 Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: 步骤 4 中的图像 2,2
    • Remove the 3 Phillips 4.5mm silver screws on the fan. Use a size 1 Phillips screwdriver
    • Remove the 1 Phillips 8mm black screw on the fan. Use a size 1 Phillips screwdriver.
  5. Samsung NP N310 HAA2US Cooling Fan Replacement: 步骤 5 中的图像 1,2 Samsung NP N310 HAA2US Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Lift the fan up, and remove the yellow tape.
    • Unplug the fan cable.
结论
Amir Afridi
于09/29/16注册
626 声望
创作了6篇指南
团队
USF Tampa, Team 4-1, Passmore Fall 2016 USF Tampa, Team 4-1, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 391
