跳转到主内容
Samsung Mythic SGH-a897 Rear Case Replacement
你所需要的
  1. Samsung Mythic SGH-a897 Rear Case Replacement, Battery: 步骤 1 中的图像 1,1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Rear Case Replacement: 步骤 2 中的图像 1,1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Rear Case Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Rear Case Replacement: 步骤 4 中的图像 1,1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
结论
Morgan Yost
于04/08/13注册
46 声望
创作了6篇指南
团队
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G1
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 286
