简介
After removing the back cover and the battery from the Samsung Mythic SGH-a897, the rear case must be removed to reach the motherboard. The tools needed are the iFixit Opening Tool to remove the rear casing and a screwdriver to remove six 5mm Phillips #0 screws.
你所需要的
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
即将完成!
结论
