当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
在这个步骤中使用的工具:
购买
Using tweezers, firmly grip the black lever at the bottom of the motherboard.
Use the tweezers to flip the black lever up so that it is upright from the motherboard.
Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
Carefully lift the capacitor away from the phone.
DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
Carefully tilt the motherboard up from the back of the phone.
Use tweezers to unclip the black connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
