跳转到主内容
Samsung Mythic SGH-a897 LCD Replacement
你所需要的
  1. Samsung Mythic SGH-a897 LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 LCD Replacement: 步骤 2 中的图像 1,1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 LCD Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 LCD Replacement: 步骤 4 中的图像 1,1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 LCD Replacement, Camera: 步骤 5 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement, Camera: 步骤 5 中的图像 2,2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 LCD Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 LCD Replacement: 步骤 7 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 LCD Replacement: 步骤 8 中的图像 1,1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 LCD Replacement: 步骤 9 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement: 步骤 9 中的图像 2,2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 LCD Replacement: 步骤 10 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement: 步骤 10 中的图像 2,2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 LCD Replacement: 步骤 11 中的图像 1,1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 LCD Replacement: 步骤 12 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement: 步骤 12 中的图像 2,2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 LCD Replacement: 步骤 13 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement: 步骤 13 中的图像 2,2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  14. Samsung Mythic SGH-a897 LCD Replacement, LCD: 步骤 14 中的图像 1,2 Samsung Mythic SGH-a897 LCD Replacement, LCD: 步骤 14 中的图像 2,2
    • Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
  15. Samsung Mythic SGH-a897 LCD Replacement: 步骤 15 中的图像 1,3 Samsung Mythic SGH-a897 LCD Replacement: 步骤 15 中的图像 2,3 Samsung Mythic SGH-a897 LCD Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
    • Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
结论
2等其他人完成本指南。
Morgan Yost
于04/08/13注册
46 声望
创作了6篇指南
团队
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G1
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 2,367
