跳转到主内容
Samsung Moment Camera Replacement
你所需要的
  1. Samsung Moment Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the back cover off the back of the phone to reveal the battery.
  2. Samsung Moment Camera Replacement: 步骤 2 中的图像 1,2 Samsung Moment Camera Replacement: 步骤 2 中的图像 2,2
    • Place a finger in one or both of the indents by the bottom of the battery. Then pull out to remove the battery from the phone.
  3. Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: 步骤 3 中的图像 1,2 Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: 步骤 3 中的图像 2,2
    • Identify and remove the 6 screws on the rear case of the phone.
  4. Samsung Moment Camera Replacement: 步骤 4 中的图像 1,2 Samsung Moment Camera Replacement: 步骤 4 中的图像 2,2
    • Using a spudger, separate the rear case of the phone from the front case.
  5. Samsung Moment Camera Replacement, Camera: 步骤 5 中的图像 1,1
    • Identify the phone's camera piece
  6. Samsung Moment Camera Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to peel back the green processing chip, exposing the wires underneath. Identify the thin golden band which connects the camera to the rest of the phone.
  7. Samsung Moment Camera Replacement: 步骤 7 中的图像 1,1
    • Using the spudger, separate the golden band from its resting dock. It should come apart fairly easily, like undoing a bit of velcro. Once separated, the camera should slide out.
结论
另外一个人完成了本指南。
Steven Cooney
于03/07/16注册
200 声望
撰写一个指南
团队
Marist, Team 1-1, Laflen Spring 2016 Marist, Team 1-1, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 267
