跳转到主内容
Samsung MV900F Screen Replacement
你所需要的
  1. Samsung MV900F Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Screen Replacement: 步骤 2 中的图像 1,1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Screen Replacement, Screen: 步骤 4 中的图像 1,2 Samsung MV900F Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Screen Replacement: 步骤 5 中的图像 1,2 Samsung MV900F Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Screen Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Screen Replacement: 步骤 8 中的图像 1,1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the old screen.
    How to replace lcd in the old screen? How to open it?
    lynda_myself - 回复
结论
To reassemble your device, follow these steps in reverse order.
Ethan Rowland
于03/03/15注册
216 声望
创作了2篇指南
团队
一条评论
Anyone an Idea where I can buy a cheap new display for that cam?
Bernhard Prieler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 844
