当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the lock towards the middle of the camera, in the same direction of the arrow.
Push the blue battery holder up in the direction of the arrow.
Pull the battery out of the battery slot.
Use tweezers to remove the four rubber screw covers.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Remove the back casing by just carefully pulling the casing off of the camera.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
Use plastic opening tool to disconnect screen connector from the control board.
Remove the old screen.
Remove the 2.381 mm screw with a Phillips #00 screwdriver.
Use the plastic opening tool to remove the silver metal lens cover.
Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
From the front of the camera, push the lens through the back of the camer.a
Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
Remove the lens assembly from the camera.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于03/03/15注册
216 声望
创作了2篇指南
徽章: 9
+ 6更多徽章
SHSU-BLACKBURNE-W15S13G2
3 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 746
