跳转到主内容
Samsung ML2510 Rear Cooling Fan Replacement
你所需要的
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 1,3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 2,3 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 3,3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Rear Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Rear Cooling Fan Replacement: 步骤 3 中的图像 1,3 Samsung ML2510 Rear Cooling Fan Replacement: 步骤 3 中的图像 2,3 Samsung ML2510 Rear Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: 步骤 4 中的图像 1,2 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: 步骤 4 中的图像 2,2
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  5. Samsung ML2510 Rear Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
终点
bbaustin
于10/12/11注册
268 声望
创作了6篇指南
团队
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G18
4 名成员
创作了12篇指南
一条评论
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,339
