跳转到主内容
Samsung ML2510 Power Button Replacement
你所需要的
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 1,3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 2,3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 3,3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: 步骤 3 中的图像 1,3 Samsung ML2510 Power Button Replacement: 步骤 3 中的图像 2,3 Samsung ML2510 Power Button Replacement: 步骤 3 中的图像 3,3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: 步骤 4 中的图像 1,3 Samsung ML2510 Power Button Replacement, Power Button: 步骤 4 中的图像 2,3 Samsung ML2510 Power Button Replacement, Power Button: 步骤 4 中的图像 3,3
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: 步骤 6 中的图像 1,3 Samsung ML2510 Power Button Replacement: 步骤 6 中的图像 2,3 Samsung ML2510 Power Button Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: 步骤 8 中的图像 1,2 Samsung ML2510 Power Button Replacement: 步骤 8 中的图像 2,2
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
终点
2等其他人完成本指南。
bbaustin
于10/12/11注册
268 声望
创作了6篇指南
团队
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G18
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 3,348
