跳转到主内容
Samsung ML2510 Motor Replacement
你所需要的
  1. Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 1,3 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 2,3 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 步骤 1 中的图像 3,3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Motor Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Motor Replacement: 步骤 3 中的图像 1,3 Samsung ML2510 Motor Replacement: 步骤 3 中的图像 2,3 Samsung ML2510 Motor Replacement: 步骤 3 中的图像 3,3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Motor Replacement, Motor: 步骤 4 中的图像 1,3 Samsung ML2510 Motor Replacement, Motor: 步骤 4 中的图像 2,3 Samsung ML2510 Motor Replacement, Motor: 步骤 4 中的图像 3,3
    • Remove the front panel by gently moving the holes on the panel, one at a time, from the pegs attached to the main body of the printer.
  5. Samsung ML2510 Motor Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
  6. Samsung ML2510 Motor Replacement: 步骤 6 中的图像 1,3 Samsung ML2510 Motor Replacement: 步骤 6 中的图像 2,3 Samsung ML2510 Motor Replacement: 步骤 6 中的图像 3,3
    • Use plastic opening tool to gently lift one side of the top panel from its peg.
    • Repeat the first process for the other side.
    • Lift the top panel from the front of the printer to remove it entirely.
  7. Samsung ML2510 Motor Replacement: 步骤 7 中的图像 1,3 Samsung ML2510 Motor Replacement: 步骤 7 中的图像 2,3 Samsung ML2510 Motor Replacement: 步骤 7 中的图像 3,3
    • Lift the left side panel up from the raised stops.
    • Gently rotate the panel, as indicated in the picture, to remove the panel entirely.
  8. Samsung ML2510 Motor Replacement: 步骤 8 中的图像 1,3 Samsung ML2510 Motor Replacement: 步骤 8 中的图像 2,3 Samsung ML2510 Motor Replacement: 步骤 8 中的图像 3,3
    • Use Phillips #2 screwdriver to remove the five, 1", Phillips, PH#2 screws on the side metal panel.
    • Remove the two, 1", Phillips, PH#2 screws on the back of the printer.
    • Flip over the metal panel to reveal the gear mechanism.
  9. Samsung ML2510 Motor Replacement: 步骤 9 中的图像 1,3 Samsung ML2510 Motor Replacement: 步骤 9 中的图像 2,3 Samsung ML2510 Motor Replacement: 步骤 9 中的图像 3,3
    • Remove the cable attached to the motor.
    • The entire panel can be removed from the rest of the printer.
    • Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
    • Replace the motor and reassemble the printer by following the instructions in reverse order.
终点
另外一个人完成了本指南。
bbaustin
于10/12/11注册
268 声望
创作了6篇指南
团队
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G18
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 4,711
