跳转到主内容
Samsung Level Box Mini Battery Replacement
你所需要的
  1. Samsung Level Box Mini Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Level Box Mini Battery Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Battery Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, remove the batteries from the device.
结论
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
9等其他人完成本指南。
dylan weiss
于02/16/17注册
134 声望
撰写一个指南
团队
USF Tampa, Team 1-4, Kass Spring 2017 USF Tampa, Team 1-4, Kass Spring 2017 的会员
USFT-KASS-S17S1G4
5 名成员
创作了4篇指南
5指南评论
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - 回复
I want to replace pcb of this device how to find it??
faraz siddiqui - 回复
I want to replace PCB of this device suggest me where to find?
faraz siddiqui - 回复
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - 回复
What kind of batterries should get ?
Aldo Eliezer Rivera Sizzo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 65
总计 9,659
