跳转到主内容
Samsung LNT4669FX-XAA TV Power Supply Board Replacement
你所需要的
    • Be sure to unplug the TV from the main wall outlet.
    • Carefully lay the TV screen down on a clean flat table with the back side facing you.
    • Using a #3 Phillips head screwdriver, remove the screws holding the back cover on.
    • Thoroughly clean the cover and boards using a damp towel (I like to use 91% isopropyl alcohol) and if heavily soiled use a vacuum with a brush.
    • Using the #3 Phillips head screwdriver, remove the screws holding the power supply board on.
    • Unplug the connectors connected to the board setting aside and carefully noting placement for later connection to the new board.
    • Insert the new power supply board into the location where the old board was located.
    • Follow the previous steps to connect the cables and screw in the screws.
    • Follow the first step in reverse to install the back cover.
    • Plug the power cord into a wall outlet and power on the TV to verify performance.
结论
You can also repair your Power Supply Board potentially by using the BN44-00166C repair kit.
See the Attached Documents schematic for further Power Supply Board details.
2等其他人完成本指南。
附加文件
James Finch
于10/14/17注册
2,366 声望
创作了13篇指南
2条评论
Power supra wod
Sajeev G - 回复
should we use the same power supply brand/type?
A Shahyadi - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 70
总计 10,802
