跳转到主内容
Samsung LN-T5265F T-Con Board Replacement
你所需要的
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: 步骤 3 中的图像 1,2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: 步骤 3 中的图像 2,2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: 步骤 4 中的图像 1,2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: 步骤 4 中的图像 2,2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: 步骤 5 中的图像 1,1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: 步骤 6 中的图像 1,1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
结论
3等其他人完成本指南。
Steven Carlton
于08/19/13注册
606 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 27
总计 10,088
