跳转到主内容
Samsung LN-T5265F Rear Case Replacement
你所需要的
  1. Samsung LN-T5265F Rear Case Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F Rear Case Replacement, Rear Case: 步骤 3 中的图像 1,2 Samsung LN-T5265F Rear Case Replacement, Rear Case: 步骤 3 中的图像 2,2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
结论
3等其他人完成本指南。
Steven Carlton
于08/19/13注册
606 声望
创作了3篇指南
一条评论
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 21
总计 2,418
