配件
无需配件。
  1. Lay the TV screen-side down on a flat, soft surface.
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    • Slide the stand out from the bottom of the TV.
  3. Remove fifteen Phillips screws securing the rear case to the front. If present, remove four Phillips screws for the VESA mount.
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
结论
3等其他人完成本指南。
Steven Carlton
于2013年08月19日注册
566 信誉积分
创作了3篇指南
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 7
总计 1,846
