当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove batteries before you disassemble the remote
Use a case opening tool to gently split the upper and lower case
Work around the entire case until the 2 halves come apart completely
Release the circuit board by gently pushing the plastic tab away from the board
Use minimal force to avoid breaking it
Lift circuit board off top cover to expose the rubber button membrane
Lift off the rubber button membrane
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
