跳转到主内容
配件
没有特定配件。
  1. Remove batteries before you disassemble the remote Use a case opening tool to gently split the upper and lower case Work around the entire case until the 2 halves come apart completely
    • Remove batteries before you disassemble the remote
    • Use a case opening tool to gently split the upper and lower case
    • Work around the entire case until the 2 halves come apart completely
  2. Release the circuit board by gently pushing the plastic tab away from the board Use minimal force to avoid breaking it
    • Release the circuit board by gently pushing the plastic tab away from the board
    • Use minimal force to avoid breaking it
    • Lift circuit board off top cover to expose the rubber button membrane
    • Lift off the rubber button membrane
  3. During reassembly make sure that you correctly place the battery cover retainer on the read case During reassembly make sure that you correctly place the battery cover retainer on the read case
    • During reassembly make sure that you correctly place the battery cover retainer on the read case
  4. When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
    • When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
结论
9等其他人完成本指南。
Richdave
于2010年04月09日注册
31,008 信誉积分
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
297 名成员
创作了983篇指南
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 44
过去的30天: 174
总计 30,165
