跳转到主内容
Samsung LA40R81BD 40in LCD TV Remote Control Disassembly
你所需要的
  1. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: 步骤 1 中的图像 1,3 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: 步骤 1 中的图像 2,3 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: 步骤 1 中的图像 3,3
    • Remove batteries before you disassemble the remote
    • Use a case opening tool to gently split the upper and lower case
    • Work around the entire case until the 2 halves come apart completely
  2. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 2 中的图像 1,2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 2 中的图像 2,2
    • Release the circuit board by gently pushing the plastic tab away from the board
    • Use minimal force to avoid breaking it
    • Lift circuit board off top cover to expose the rubber button membrane
    • Lift off the rubber button membrane
  3. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 3 中的图像 1,2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 3 中的图像 2,2
    • During reassembly make sure that you correctly place the battery cover retainer on the read case
  4. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 4 中的图像 1,2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: 步骤 4 中的图像 2,2
    • When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
结论
11等其他人完成本指南。
Richdave
于04/09/10注册
32,729 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 39
过去 30 天: 162
总计 39,140
