简介
Flash bulb soldered to circuit board with capacitor, so it is not possible to only replace flash bulbs.
工具
配件
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Remove the screws holding the circuit board.
After you remove the screws, carefully remove the circuit board.
另外一个人完成了本指南。
