跳转到主内容
加入维修社区 - 创建账户
Samsung L100 flash assembly replacement
你所需要的
  1. Samsung L100 flash assembly replacement, Removing Back Cover: 步骤 1 中的图像 1,3 Samsung L100 flash assembly replacement, Removing Back Cover: 步骤 1 中的图像 2,3 Samsung L100 flash assembly replacement, Removing Back Cover: 步骤 1 中的图像 3,3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 flash assembly replacement: 步骤 2 中的图像 1,2 Samsung L100 flash assembly replacement: 步骤 2 中的图像 2,2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 flash assembly replacement: 步骤 3 中的图像 1,3 Samsung L100 flash assembly replacement: 步骤 3 中的图像 2,3 Samsung L100 flash assembly replacement: 步骤 3 中的图像 3,3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 flash assembly replacement: 步骤 4 中的图像 1,1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 flash assembly replacement: 步骤 5 中的图像 1,1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 flash assembly replacement, Flash Circuit Board: 步骤 6 中的图像 1,1
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  7. Samsung L100 flash assembly replacement: 步骤 7 中的图像 1,2 Samsung L100 flash assembly replacement: 步骤 7 中的图像 2,2
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  8. Samsung L100 flash assembly replacement: 步骤 8 中的图像 1,1
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  9. Samsung L100 flash assembly replacement: 步骤 9 中的图像 1,1
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  10. Samsung L100 flash assembly replacement: 步骤 10 中的图像 1,3 Samsung L100 flash assembly replacement: 步骤 10 中的图像 2,3 Samsung L100 flash assembly replacement: 步骤 10 中的图像 3,3
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
结论
另外一个人完成了本指南。
Adriel
于04/15/10注册
126 声望
创作了2篇指南
团队
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G17
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 29
总计 4,252
