跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
If camera lens jams or breaks, this guide will help you replace it.
  1. Remove the six external screws from the camera using a Phillips #0 screwdriver. After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera. Be careful, make sure you don't lose the screws.
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Carefully squeeze the top right corner of the camera and pry off the external cover.
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Carefully pull off the back cover, parts behind the back of the case might fall out.
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Remove the front cover, it comes off easily.
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  7. Remove green tape from ribbon.
    • Remove green tape from ribbon.
  8. Remove four screws around lens. Remove four screws around lens.
    • Remove four screws around lens.
  9. Use spudger to remove ribbon connecting the circuit board from lens.
    • Use spudger to remove ribbon connecting the circuit board from lens.
  10. Remove lens from camera.
    • Remove lens from camera.
结论
5等其他人完成本指南。
Adriel
于2010年04月15日注册
120 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G17
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 9,113
