跳转到主内容
Samsung L100 Setting Knob Spring
你所需要的
  1. Samsung L100 Setting Knob Spring, Removing Back Cover: 步骤 1 中的图像 1,3 Samsung L100 Setting Knob Spring, Removing Back Cover: 步骤 1 中的图像 2,3 Samsung L100 Setting Knob Spring, Removing Back Cover: 步骤 1 中的图像 3,3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 Setting Knob Spring: 步骤 2 中的图像 1,2 Samsung L100 Setting Knob Spring: 步骤 2 中的图像 2,2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 Setting Knob Spring: 步骤 3 中的图像 1,3 Samsung L100 Setting Knob Spring: 步骤 3 中的图像 2,3 Samsung L100 Setting Knob Spring: 步骤 3 中的图像 3,3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 Setting Knob Spring: 步骤 4 中的图像 1,1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 Setting Knob Spring: 步骤 5 中的图像 1,1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 Setting Knob Spring, Flash Circuit Board: 步骤 6 中的图像 1,1
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  7. Samsung L100 Setting Knob Spring: 步骤 7 中的图像 1,2 Samsung L100 Setting Knob Spring: 步骤 7 中的图像 2,2
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  8. Samsung L100 Setting Knob Spring: 步骤 8 中的图像 1,1
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  9. Samsung L100 Setting Knob Spring: 步骤 9 中的图像 1,1
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  10. Samsung L100 Setting Knob Spring: 步骤 10 中的图像 1,3 Samsung L100 Setting Knob Spring: 步骤 10 中的图像 2,3 Samsung L100 Setting Knob Spring: 步骤 10 中的图像 3,3
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
  11. Samsung L100 Setting Knob Spring, Setting Knob Spring: 步骤 11 中的图像 1,1
    • Face the bottom of the Flash Circuit board towards you.
    • Remove the one screw that's located on the left side of the lens.
  12. Samsung L100 Setting Knob Spring: 步骤 12 中的图像 1,1
    • Take the flash circuit board and turn it over.
    • Remove the plastic setting knob.
    • Make sure to keep copper spring inside of the slot.
  13. Samsung L100 Setting Knob Spring: 步骤 13 中的图像 1,3 Samsung L100 Setting Knob Spring: 步骤 13 中的图像 2,3 Samsung L100 Setting Knob Spring: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Take out and replace the Setting Knob Spring with tweezers.
结论
andyhe
于04/15/10注册
81 声望
撰写一个指南
团队
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G17
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 3,245
