跳转到主内容
Samsung L100 LCD Screen Replacement
你所需要的
  1. Samsung L100 LCD Screen Replacement, Removing Back Cover: 步骤 1 中的图像 1,3 Samsung L100 LCD Screen Replacement, Removing Back Cover: 步骤 1 中的图像 2,3 Samsung L100 LCD Screen Replacement, Removing Back Cover: 步骤 1 中的图像 3,3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 LCD Screen Replacement: 步骤 2 中的图像 1,2 Samsung L100 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 LCD Screen Replacement: 步骤 3 中的图像 1,3 Samsung L100 LCD Screen Replacement: 步骤 3 中的图像 2,3 Samsung L100 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,2 Samsung L100 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 2,2
    • Remove the screws holding the circuit board.
    • Carefully remove the circuit board.
  7. Samsung L100 LCD Screen Replacement: 步骤 7 中的图像 1,2 Samsung L100 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully lift circuit board from camera.
    • Circuit board still attached to camera by ribbon.
  8. Samsung L100 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the front cover. It should come off easily.
    • Buttons might fall out when you remove the front cover.
  9. Samsung L100 LCD Screen Replacement: 步骤 9 中的图像 1,2 Samsung L100 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the green tape that holds the LCD screen.
    • Carefully lift the LCD Screen.
  10. Samsung L100 LCD Screen Replacement: 步骤 10 中的图像 1,3 Samsung L100 LCD Screen Replacement: 步骤 10 中的图像 2,3 Samsung L100 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Flip the camera over to the other side.
    • Lift the black strip and the ribbon should easily come out.
    • The LCD Screen should be completely separated from the camera now.
  11. Samsung L100 LCD Screen Replacement: 步骤 11 中的图像 1,2 Samsung L100 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Insert the new LCD Screen by pushing the ribbon into the slot.
    • Flip the black strip back down to lock the ribbon in.
    • Your new LCD Screen should be connected to the camera now.
结论
另外一个人完成了本指南。
Hasit
于04/15/10注册
207 声望
创作了2篇指南
团队
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G17
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 6,362
