当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
Failure to open USB port cover at this stage may result in damaging the device.
To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
Do not be alarmed if the volume and hold buttons are removed from the motherboard.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
A moderate amount of force may need to be applied.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
