Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
Failure to open USB port cover at this stage may result in damaging the device.
To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
Do not be alarmed if the volume and hold buttons are removed from the motherboard.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
A moderate amount of force may need to be applied.
Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
If necessary, use the iFixit opening tool to completely free the casing.
Be careful not to sever the wire connecting the outer casing to the display board.
Using the iFixit opening tool, remove the click wheel from the board.
After you have freed the edges, use the spudger to release the clip holding it flush to the board.
在这个步骤中使用的工具:
购买
Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
This is glued on so a moderate amount of force may be needed.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
