跳转到主内容
加入维修社区 - 创建账户
Samsung Juke Outer Casing Replacement
你所需要的
  1. Samsung Juke Outer Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Outer Casing Replacement: 步骤 2 中的图像 1,2 Samsung Juke Outer Casing Replacement: 步骤 2 中的图像 2,2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Outer Casing Replacement, Camera/Speaker: 步骤 3 中的图像 1,1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Outer Casing Replacement: 步骤 4 中的图像 1,1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Outer Casing Replacement: 步骤 5 中的图像 1,3 Samsung Juke Outer Casing Replacement: 步骤 5 中的图像 2,3 Samsung Juke Outer Casing Replacement: 步骤 5 中的图像 3,3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Outer Casing Replacement: 步骤 6 中的图像 1,1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Outer Casing Replacement: 步骤 7 中的图像 1,2 Samsung Juke Outer Casing Replacement: 步骤 7 中的图像 2,2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Outer Casing Replacement: 步骤 8 中的图像 1,2 Samsung Juke Outer Casing Replacement: 步骤 8 中的图像 2,2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke Outer Casing Replacement, Motherboard: 步骤 9 中的图像 1,2 Samsung Juke Outer Casing Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke Outer Casing Replacement: 步骤 10 中的图像 1,2 Samsung Juke Outer Casing Replacement: 步骤 10 中的图像 2,2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke Outer Casing Replacement: 步骤 11 中的图像 1,3 Samsung Juke Outer Casing Replacement: 步骤 11 中的图像 2,3 Samsung Juke Outer Casing Replacement: 步骤 11 中的图像 3,3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke Outer Casing Replacement, Keyboard: 步骤 12 中的图像 1,3 Samsung Juke Outer Casing Replacement, Keyboard: 步骤 12 中的图像 2,3 Samsung Juke Outer Casing Replacement, Keyboard: 步骤 12 中的图像 3,3
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
  13. Samsung Juke Outer Casing Replacement, Click Wheel: 步骤 13 中的图像 1,2 Samsung Juke Outer Casing Replacement, Click Wheel: 步骤 13 中的图像 2,2
    • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
    • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
  14. Samsung Juke Outer Casing Replacement: 步骤 14 中的图像 1,3 Samsung Juke Outer Casing Replacement: 步骤 14 中的图像 2,3 Samsung Juke Outer Casing Replacement: 步骤 14 中的图像 3,3
    • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
    • If necessary, use the iFixit opening tool to completely free the casing.
    • Be careful not to sever the wire connecting the outer casing to the display board.
  15. Samsung Juke Outer Casing Replacement: 步骤 15 中的图像 1,3 Samsung Juke Outer Casing Replacement: 步骤 15 中的图像 2,3 Samsung Juke Outer Casing Replacement: 步骤 15 中的图像 3,3
    • Using the iFixit opening tool, remove the click wheel from the board.
    • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
  16. Samsung Juke Outer Casing Replacement: 步骤 16 中的图像 1,3 Samsung Juke Outer Casing Replacement: 步骤 16 中的图像 2,3 Samsung Juke Outer Casing Replacement: 步骤 16 中的图像 3,3
    • Unlock the ribbon connection by pressing down on the black clip.
    • Carefully pull the click wheel away from the device.
  17. Samsung Juke Outer Casing Replacement, Outer Casing: 步骤 17 中的图像 1,2 Samsung Juke Outer Casing Replacement, Outer Casing: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
    • This is glued on so a moderate amount of force may be needed.
结论
2等其他人完成本指南。
Ryan Turner
于04/15/10注册
107 声望
创作了2篇指南
团队
Cal Poly, Team 6-18, Maness Spring 2010 Cal Poly, Team 6-18, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G18
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 2,551
