简介
This guide outlines how to replace the click wheel on the front of the Samsung Juke.
配件
没有特定配件。
Locate the button on the bottom of the phone. Once located, press and hold the button down.
Use the size 00 Phillips screwdriver to remove the four screws located on the back of the phone. These screws are circled in yellow in the given image.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iPod opening tool to pry the keypad from the hinge on the back of the device.
Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
Using a phillips 00 screwdriver, remove all six screws on the back of the device.
另外一个人完成了本指南。
一条评论
All I have to say is: THANK YOU!
My juke's click wheel got stuck, which was draining my battery. I followed the incredibly easy to understand instructions and pictures and was able to free my click wheel. I cleaned the wheel and put my phone back together by going backward though the instructions, turned on my phone, and IT WORKED PERFECTLY. This saved my from having to buy a new, large and extremely expensive phone.
Thank You so much for these great, step-by-step instructions!
