跳转到主内容
Samsung Jack Speaker Replacement
你所需要的
  1. Samsung Jack Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: 步骤 2 中的图像 1,1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Jack Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Jack Speaker Replacement: 步骤 4 中的图像 3,3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: 步骤 6 中的图像 1,1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Jack Speaker Replacement: 步骤 7 中的图像 2,2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: 步骤 8 中的图像 1,1
    • Lift the speaker out of its compartment.
结论
另外一个人完成了本指南。
Paul Piller
于04/12/11注册
56 声望
创作了5篇指南
团队
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G57
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,727
