跳转到主内容
简介
Use this guide to install a rear case.
  1. Slide the battery cover downwards with pressure focused on the center of the cover.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Grasp the bottom left and right corners of the battery and lift it from its housing.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Lift the rear case off of the phone.
    • Lift the rear case off of the phone.
结论
Paul Piller
于2011年04月12日注册
56 信誉积分
创作了5篇指南
团队
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G57
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,089
