当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
Insert the Plastic Opening Tool in between the front and rear cases.
Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
Use a spudger to disconnect the Motherboard ribbon cable.
The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
Insert the spudger under the bottom left corner of the LCD screen.
Use the spudger to gently pry the LCD screen out of its frame.
Gently remove the screen from the frame.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
