跳转到主内容
加入维修社区 - 创建账户
Samsung Jack LCD Replacement
你所需要的
    1. Samsung Jack LCD Replacement, Battery: 步骤 1 中的图像 1,1
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 2 中的图像 1,1
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      询问修复机器人
      添加评论
    1. Samsung Jack LCD Replacement, Rear Case: 步骤 3 中的图像 1,1
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 4 中的图像 1,3 Samsung Jack LCD Replacement: 步骤 4 中的图像 2,3 Samsung Jack LCD Replacement: 步骤 4 中的图像 3,3
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      询问修复机器人
      添加评论
    3. Samsung Jack LCD Replacement: 步骤 5 中的图像 1,1
      • Lift the rear case off of the phone.
      询问修复机器人
      添加评论
    1. Samsung Jack LCD Replacement, Antenna: 步骤 6 中的图像 1,1
      • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 7 中的图像 1,3 Samsung Jack LCD Replacement: 步骤 7 中的图像 2,3 Samsung Jack LCD Replacement: 步骤 7 中的图像 3,3
      • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
      • Use a spudger to remove the wire connector under the antenna.
      询问修复机器人
      添加评论
    1. Samsung Jack LCD Replacement, Speaker: 步骤 8 中的图像 1,1
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 9 中的图像 1,2 Samsung Jack LCD Replacement: 步骤 9 中的图像 2,2
      • Use the spudger to detach the speaker ribbon cable.
      询问修复机器人
      添加评论
    3. Samsung Jack LCD Replacement: 步骤 10 中的图像 1,1
      • Lift the speaker out of its compartment.
      询问修复机器人
      添加评论
    1. Samsung Jack LCD Replacement, Motherboard: 步骤 11 中的图像 1,1
      • Remove the power and volume buttons on the right side of the Motherboard.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 12 中的图像 1,2 Samsung Jack LCD Replacement: 步骤 12 中的图像 2,2
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      询问修复机器人
      添加评论
    3. Samsung Jack LCD Replacement: 步骤 13 中的图像 1,2 Samsung Jack LCD Replacement: 步骤 13 中的图像 2,2
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      询问修复机器人
      添加评论
    4. Samsung Jack LCD Replacement: 步骤 14 中的图像 1,3 Samsung Jack LCD Replacement: 步骤 14 中的图像 2,3 Samsung Jack LCD Replacement: 步骤 14 中的图像 3,3
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      询问修复机器人
      添加评论
    5. Samsung Jack LCD Replacement: 步骤 15 中的图像 1,2 Samsung Jack LCD Replacement: 步骤 15 中的图像 2,2
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      询问修复机器人
      添加评论
    6. Samsung Jack LCD Replacement: 步骤 16 中的图像 1,1
      • Lift the Motherboard off of the phone.
      询问修复机器人
      添加评论
    1. Samsung Jack LCD Replacement, LCD: 步骤 17 中的图像 1,3 Samsung Jack LCD Replacement, LCD: 步骤 17 中的图像 2,3 Samsung Jack LCD Replacement, LCD: 步骤 17 中的图像 3,3
      • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
      • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
      询问修复机器人
      添加评论
    2. Samsung Jack LCD Replacement: 步骤 18 中的图像 1,2 Samsung Jack LCD Replacement: 步骤 18 中的图像 2,2
      • Lift up the LCD frame.
      询问修复机器人
      添加评论
    3. Samsung Jack LCD Replacement: 步骤 19 中的图像 1,3 Samsung Jack LCD Replacement: 步骤 19 中的图像 2,3 Samsung Jack LCD Replacement: 步骤 19 中的图像 3,3
      • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
      • Insert the spudger under the bottom left corner of the LCD screen.
      • Use the spudger to gently pry the LCD screen out of its frame.
      • Gently remove the screen from the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Paul Piller
于04/12/11注册
56 声望
创作了5篇指南
团队
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G57
4 名成员
创作了42篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 2,257
