跳转到主内容
简介
Use this guide to remove the old keyboard and install a new one.
  1. Slide the battery cover downwards with pressure focused on the center of the cover.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Grasp the bottom left and right corners of the battery and lift it from its housing.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Lift the rear case off of the phone.
    • Lift the rear case off of the phone.
  6. Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet. Use a spudger to remove the wire connector under the antenna. Use a spudger to remove the wire connector under the antenna.
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
  8. Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  9. Use the spudger to detach the speaker ribbon cable. Use the spudger to detach the speaker ribbon cable.
    • Use the spudger to detach the speaker ribbon cable.
  10. Lift the speaker out of its compartment.
    • Lift the speaker out of its compartment.
  11. Remove the power and volume buttons on the right side of the Motherboard.
    • Remove the power and volume buttons on the right side of the Motherboard.
  12. Use a spudger to detach the camera ribbon cable. Lift the camera off of the Motherboard.
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  13. Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard. Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  14. Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard. Use a spudger to carefully pull the ribbon cables away from the ZIF connectors. Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  15. There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet. Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  16. Lift the Motherboard off of the phone.
    • Lift the Motherboard off of the phone.
  17. The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool between the LCD frame and the front case of the phone. Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
  18. Lift up the LCD frame. Lift up the LCD frame.
    • Lift up the LCD frame.
  19. The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard. The keyboard and directional keys are glued separately to the LCD frame. Insert the spudger between the keyboard and the frame.
    • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
    • The keyboard and directional keys are glued separately to the LCD frame.
    • Insert the spudger between the keyboard and the frame.
    • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
  20. Insert the spudger between the directional keys and the frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame. Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
    • Insert the spudger between the directional keys and the frame.
    • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
结论
另外一个人完成了本指南。
Jaime Serrano
于2011年04月11日注册
59 信誉积分
创作了2篇指南
团队
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G57
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 2,024
