当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Grasp the bottom left and right corners of the battery and lift it from its housing.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
Insert the Plastic Opening Tool in between the front and rear cases.
Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Lift the rear case off of the phone.
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
Use a spudger to remove the wire connector under the antenna.
取消:我没有完成这个指南。
与6其他贡献者
于04/12/11注册
56 声望
创作了5篇指南
徽章: 9
+ 6更多徽章
CPSU-AMIDO-S11S24G57
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 2,326
