本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to install a new speaker.
你所需要的
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
即将完成!
结论
