当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
There are three strips total: one on the right, left, and top of the phone.
Using the plastic opener tool, remove the speaker from its setting.
Pry where the wire enters the speaker.
The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
