跳转到主内容
加入维修社区 - 创建账户
Samsung Instinct Front Case Replacement
你所需要的
  1. Samsung Instinct Front Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Front Case Replacement: 步骤 2 中的图像 1,1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Front Case Replacement, Back Case: 步骤 3 中的图像 1,1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Front Case Replacement: 步骤 4 中的图像 1,2 Samsung Instinct Front Case Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Front Case Replacement: 步骤 5 中的图像 1,1
    • Lift the casing off of the phone.
  6. Samsung Instinct Front Case Replacement, Antenna: 步骤 6 中的图像 1,1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Front Case Replacement: 步骤 7 中的图像 1,1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Front Case Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Front Case Replacement: 步骤 9 中的图像 1,1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Front Case Replacement, Front Case: 步骤 10 中的图像 1,1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Front Case Replacement: 步骤 11 中的图像 1,3 Samsung Instinct Front Case Replacement: 步骤 11 中的图像 2,3 Samsung Instinct Front Case Replacement: 步骤 11 中的图像 3,3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Front Case Replacement: 步骤 12 中的图像 1,1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Front Case Replacement: 步骤 13 中的图像 1,2 Samsung Instinct Front Case Replacement: 步骤 13 中的图像 2,2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Front Case Replacement: 步骤 14 中的图像 1,1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Front Case Replacement: 步骤 15 中的图像 1,1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
结论
Jacob Michener
于10/10/11注册
31 声望
创作了2篇指南
团队
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G13
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 831
