工具
配件
没有特定配件。
Apply pressure to the back cover and slide it forward towards the camera.
Lift the back cover off the phone.
Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
Once the motherboard is removed from the frame, use the pry tool to remove the camera.
Insert the pry bar between the camera and the frame then lift up.
The camera is held in by adhesive so it will require some force to remove.
You have now successfully removed the camera from your Samsung Instinct.
2等其他人完成本指南。
