当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
Pry the battery free. It will pivot in the direction of the white arrow.
Remove the back cover by gently prying around the top and bottom edges with the spudger.
It may help to slide the touchscreen upwards when removing the back panel.
The side buttons will become loose and will fall out, so put these in a safe place.
To free the circuit board, remove the black wire that is holding it down.
You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
