跳转到主内容
Samsung Impression Camera Replacement
你所需要的
  1. Samsung Impression Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Camera Replacement: 步骤 2 中的图像 1,2 Samsung Impression Camera Replacement: 步骤 2 中的图像 2,2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Camera Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Camera Replacement: 步骤 4 中的图像 1,1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Camera Replacement, Circuit Board: 步骤 5 中的图像 1,1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  6. Samsung Impression Camera Replacement: 步骤 6 中的图像 1,2 Samsung Impression Camera Replacement: 步骤 6 中的图像 2,2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
  7. Samsung Impression Camera Replacement, Camera: 步骤 7 中的图像 1,2 Samsung Impression Camera Replacement, Camera: 步骤 7 中的图像 2,2
    • Turn the circuit board over.
    • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
    • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
结论
Saul Villatoro
于04/25/11注册
260 声望
创作了7篇指南
团队
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G10
4 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,675
