简介
How to remove & replace the phone's antenna.
你所需要的
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
另外一个人完成了本指南。
