跳转到主内容
Samsung HMX-QF20 Internal Microphone Replacement
你所需要的
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: 步骤 1 中的图像 1,1
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: 步骤 3 中的图像 1,1
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: 步骤 4 中的图像 1,1
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: 步骤 5 中的图像 1,1
    • Remove the three 5 mm screws surrounding the lens.
结论
Ian Dorset
于03/11/15注册
225 声望
创作了2篇指南
团队
Marist, Team 1-5, Laflen Spring 2015 Marist, Team 1-5, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 436
