跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. 这个步骤还没有翻译 帮忙翻译一下
    Pull the release tab away from the battery. Slide the battery towards the release tab and then pull the battery away from the camcorder. Slide the battery towards the release tab and then pull the battery away from the camcorder.
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Rotate the camcorder so that the strap side is facing you. Locate and remove the three 4.5mm  Phillips #00 screws around the hand strap.
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Rotate the camcorder so that the battery slot is facing you. Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Rotate the camcorder so you are looking at the bottom of the camcorder. Locate and remove the last three 4.5mm Phillips #00 screws.
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. 这个步骤还没有翻译 帮忙翻译一下
    With both hands, pull the side strap apart from the rest of the camcorder. With both hands, pull the side strap apart from the rest of the camcorder. With both hands, pull the side strap apart from the rest of the camcorder.
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. 这个步骤还没有翻译 帮忙翻译一下
    Locate plastic clips of the record button. With tweezers squeeze together the two plastic clips and push the button out. Wiggle and pull the record button to remove completely.
    • Locate plastic clips of the record button.
    • With tweezers squeeze together the two plastic clips and push the button out.
    • Wiggle and pull the record button to remove completely.
终点
Amir Harb
于2017年09月26日注册
697 信誉积分
创作了6篇指南
团队
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G1
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 168
