本指南有最近更改,您可查看未经巡查的最新版本。
简介
After several times of using buttons, they can become stuck or faulty. This guide can be used to loosen or replace the record button.
你所需要的
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
Locate plastic clips of the record button.
With tweezers squeeze together the two plastic clips and push the button out.
Wiggle and pull the record button to remove completely.
