跳转到主内容
Samsung HMX-F90 Lens Replacement
你所需要的
  1. Samsung HMX-F90 Lens Replacement, Battery: 步骤 1 中的图像 1,3 Samsung HMX-F90 Lens Replacement, Battery: 步骤 1 中的图像 2,3 Samsung HMX-F90 Lens Replacement, Battery: 步骤 1 中的图像 3,3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: 步骤 2 中的图像 1,2 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: 步骤 2 中的图像 2,2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: 步骤 3 中的图像 1,2 Samsung HMX-F90 Lens Replacement: 步骤 3 中的图像 2,2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: 步骤 4 中的图像 1,2 Samsung HMX-F90 Lens Replacement: 步骤 4 中的图像 2,2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: 步骤 5 中的图像 1,3 Samsung HMX-F90 Lens Replacement: 步骤 5 中的图像 2,3 Samsung HMX-F90 Lens Replacement: 步骤 5 中的图像 3,3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: 步骤 6 中的图像 1,2 Samsung HMX-F90 Lens Replacement, Lens: 步骤 6 中的图像 2,2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: 步骤 7 中的图像 1,2 Samsung HMX-F90 Lens Replacement: 步骤 7 中的图像 2,2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: 步骤 8 中的图像 1,2 Samsung HMX-F90 Lens Replacement: 步骤 8 中的图像 2,2
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: 步骤 9 中的图像 1,3 Samsung HMX-F90 Lens Replacement: 步骤 9 中的图像 2,3 Samsung HMX-F90 Lens Replacement: 步骤 9 中的图像 3,3
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: 步骤 10 中的图像 1,3 Samsung HMX-F90 Lens Replacement: 步骤 10 中的图像 2,3 Samsung HMX-F90 Lens Replacement: 步骤 10 中的图像 3,3
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
结论
3等其他人完成本指南。
Amir Harb
于09/26/17注册
705 声望
创作了6篇指南
团队
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 1,162
