跳转到主内容
Samsung HD Pro Camera Lens Replacement
你所需要的
  1. Samsung HD Pro Camera Lens Replacement, Casing: 步骤 1 中的图像 1,1
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro Camera Lens Replacement: 步骤 4 中的图像 1,1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro Camera Lens Replacement: 步骤 5 中的图像 1,1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 1,1
    • Locate the camera lens and unscrew it with your hands.
  7. Samsung HD Pro Camera Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the washers between the lens and motherboard.
结论
Hunter Wood
于01/18/17注册
101 声望
撰写一个指南
一条评论
Where do you purchase a new lens?
Gary - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 829
