跳转到主内容
Samsung Glyde Motherboard Replacement
你所需要的
  1. Samsung Glyde Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Samsung Glyde Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Glyde Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Glyde Motherboard Replacement: 步骤 5 中的图像 2,2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Glyde Motherboard Replacement: 步骤 6 中的图像 2,2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Glyde Motherboard Replacement: 步骤 7 中的图像 2,2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Motherboard Replacement: 步骤 8 中的图像 1,3 Samsung Glyde Motherboard Replacement: 步骤 8 中的图像 2,3 Samsung Glyde Motherboard Replacement: 步骤 8 中的图像 3,3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Motherboard Replacement: 步骤 9 中的图像 1,2 Samsung Glyde Motherboard Replacement: 步骤 9 中的图像 2,2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
结论
Stephen
于10/12/11注册
26 声望
撰写一个指南
团队
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G12
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,104
