简介
This guide will provide a step by step procedure for installing the camera.
你所需要的
Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
Using your fingers, take the case off.
Use your thumb and index finger to grip the camera connector.
Pull the camera connector upwards to detach the camera.
